Architectural Shingle Replacement: 2 Tips Architectural Shingle Replacement: 2 Tips
If you are looking to replace some of your architectural shingle pieces, then you need to make sure that you get a replacement which looks very similar to the old pieces. Architectural shingle is a very popular style of roofing material which is usually coated with a surface that makes them heavier and stronger than any other type of shingle. Architectural shingle is also more durable than other shingles, so it is unusual to need to replace them.
1. Check the Warranty
Most architectural shingle installations are guaranteed for around 40 years, so if you do want to do a replacement, you first need to make sure that you are not going to void your warranty by replacing the shingles yourself. You should also check with the person who originally installed the shingle, as they may have some spare pieces which could save you a lot of money.
2. Replace the Strip
Most forms of architectural shingle come in strips, so if you are looking to replace a few, you will need to remove the entire strip of shingles, and replace them with a new one. This can be a significant job, so you may need to get professional help to take up each strip and replace it with a new one.
