Are all hinge pin door stops a standared size? Are all hinge pin door stops a standared size?
Hinge pin door stops are available in several standard sizes, to fit doors of various sizes. The bigger door stops can be used for heavier doors, and smaller ones for lighter doors. Make sure you choose the right sized hinge pin door stop for your door. The bigger the door stop, the heavier it will be. A heavier door stop on a lighter door can put extra strain on the door levers, and it may even get detached from the frame, leaving the door damaged. If you are not sure what size suits your door, you can get proper advice from your local hardware store. They are also available in different materials, to suit your interior.
