Are Bleach Smells in Home Air Conditioners Normal?
Bleach is an effective cleaning agent, but is that bleach smell coming from your home air conditioner normal, or might it signal a problem? Is it something you should seriously consider removing from the home environment? These are valid questions because the last thing you want is for you or your family to breathe something harmful.
1st Possible Cause – Regular Cleaning
It’s suggested that you pour a cup of regular household bleach once a month into the drain that holds the air conditioner and that might be what your nose has picked up on.
2nd Possible Cause – A Dirty Filter
This bleach smell could just mean the air filter is dirty, and in that case, check it to see if it needs to be replaced.
3rd Possible Cause – Refrigeration leak
That scent you notice might signal a leak in the refrigeration system, however. If the smell persists, even after replacing the air filter, you might want to contact a repairman, just to be safe.
Whenever you smell something out of the ordinary coming from an appliance, it’s always better to be safe than sorry. If you can’t get rid of it with a few simple maintenance tasks, such as changing a filter, be sure to contact an expert.
