Are Ceramic Heaters Energy Efficient?
Ceramic heaters are a type of electric heater that spread heat through convection. These heaters consist of ceramic plates with aluminum baffles or coils. The ceramic gets heated up when electricity passes through it and it passes on this heat to the aluminum baffles, which in turn spread the heat to the room by way of convection.
Suited to Small Spaces
Ceramic heaters are usually small in size and can be easily carried from room to room. They are more energy efficient as compared to other space heaters such as radiant space heaters or oil-filled space heaters. However, most ceramic space heaters work best in small areas. For larger areas you must look at space heating options such as baseboard heating, a stove or a fireplace.
Automated Features
Ceramic heaters provide superior safety. This is because the elements do not excessively heat up and actually remain somewhat cool to the touch. This greatly reduces the risk of burns or accidental fires. Also, most ceramic heaters have features such as timers and automatic shut off, which enable you to save electricity and money. Overall, ceramic heaters provide great value and energy efficiency, especially if you want to heat up a small area.
