Are Porcelain Deck Tiles Weather Resistant?
Installing deck tiles can provide you with a functional and beautiful space. When you want to improve the condition of your outdoor space, deck tiles are one of the best ways to do so. There are a number of different types of materials that can be made into deck tiles. Wooden deck tiles and porcelain tile are some of the most popular choices. While we know that wood can be treated to withstand weather conditions, you may be wondering if putting porcelain tile will be alright. Here are a few things to consider about putting porcelain tile outside on a deck.
Density
Porcelain tile can be put outdoors mainly because of its density. When compared to ceramic or other types of tile, porcelain provides you with an extremely dense tile. When you put tile outside, it is going to get wet. With ceramic, the rain would soak down into the tile. If the temperature drops below freezing, it can crack. With porcelain, you do not have to worry about this because moisture is not going to soak down into the tile surface.
Hardness
With the hardness that porcelain tile provides, you do not have to worry about hail or wind damage. It will not be dented or scratched very easily. It is safe from all types of weather.
