Are Stamped Concrete Pool Decks Slippery? Are Stamped Concrete Pool Decks Slippery?
Stamped concrete pool decks are among the most beautiful and durable decks that you could have. However, you may have some concerns about whether this type of deck will be too slippery to put around the outside of the pool. If you have small children that like to run, this can be an important issue for you. There are certain types of concrete pool decks that could be slippery. However, you can choose between a number of different textures when you have yours installed. If you specify that you want a textured pool deck, the contractor should be able to make it rough enough so that it will not be slippery. Keep in mind that it is never safe to run around a swimming pool and that it is best to wear shoes with traction on wet surfaces.
