Are stone or brick paths easier to install?
Installation of either stone or brick paths will require a lot of work and time spent, so this should be expected. However, comparing the 2, it is easier to install a stone path than brick, because you don’t have to be as precise. Brick laying requires precision and exact fitting of the bricks, in order to achieve a clean and uniform design for the path. For stone paths, the same preparation is more or less done, but you are freer to place the stones anywhere you want, depending on the design layout you choose.
