Bamboo Flooring Durability Bamboo Flooring Durability
Most people who are planning to make use of bamboo flooring are somewhat concerned with bamboo flooring durability. This is quite understandable since lumber and other materials are the usual choices for many due to their durability. However, more people are becoming aware of the benefits of using bamboo flooring. Since bamboo initiates a very eco-friendly environment, it has been the choice of many people for their flooring needs. Bamboo is a grass, but its strength and hardness is taken into account because it is denser than many hardwoods.
Bamboo has been popular in the market for a considerable period of time already. But some people are still quite skeptical about bamboo flooring durability. To enlighten you with the durability of bamboo flooring, here are some features that you should consider:
High density
Bamboo has its own natural process to keep itself naturally hard and durable. Although hardness and durability are two different entities, hardness helps determine the durability of an object. According to the Janka hardness Scale, bamboo flooring is set much higher than other popular woods used for flooring such as cherry, walnut, true teak, read, and white oak; and because of that quality, bamboo takes in less moisture than hardwood flooring.
Wide variety
Different varieties of bamboos have different durability levels. For instance, the strand bamboo is the most durable type based on Janka scores. It follows the three highest rated hardwood floors: Brazilian walnut, Tiete chestnut, and Brazilian teak. Strand bamboo is followed by distressed, solid, and engineered bamboos. That basically means better varieties of bamboo are more durable. You can choose from among the wide variety of designs, all of which provide the same bamboo flooring durability
Easier to grow
Compared to other hardwood flooring, it takes only three to six years for a bamboo to fully mature while other trees such as oak trees, usually takes about 90 years to fully mature. Thus makes bamboo a better renewable source. In China, where most bamboo varieties are imported, the bamboo exportation is one of the flourishing industries. They see to it that the bamboos they provide for flooring have high quality and are really durable.
 Technology improves its quality
 Bamboo floors are heated using steam treatment in a process called carbonization. Through this process, the desired color and sheen of the bamboo flooring is achieved. Carbonization also improves the durability of the bamboo flooring which makes it more appropriate for its purpose. To those who do not prefer the carbonized bamboo flooring, they may use those that are either bleached or painted. Aside from the color and tone, manufacturers have also developed ways to improve the bamboo flooring’s texture and finish. This gives consumers better reason to make use of bamboo flooring in their houses.
Cost and efficiency
Unlike other flooring materials, bamboo costs less than hardwood. You may still be convinced that there is hardwood flooring superior to bamboo, but they also cost much more than bamboo. Bamboo floorings do the same job and you enjoy the same quality, but you do not exhaust your pocket. Aside from that, you also do not have to spend extra on its maintenance because the cost of bamboo flooring maintenance is minimal.
