Basement Dehumidifier Temperature Guide
Using a basement dehumidifier is the most undemanding method of solving your basement’s moisture-related problems. Dehumidifiers require one-time installation and offer years of uninterrupted service; furthermore, they need minimal maintenance.
A dehumidifier also increases the lifecycle of your basement waterproofing coatings by ensuring that a minimal amount of moisture seeps through the coated surfaces. Contemporary basement dehumidifiers are offered in stylish designs that complement the decor of the surrounding area.
Understanding Basement Dehumidifier Requirement
Dehumidifiers are critical for ensuring that moisture doesn't seep into the basement area, even if you have insulated your basement with weatherproofing or waterproofing synthetic applications. Moisture seepage is the most prominent cause of basement problems such as mold, surface peeling, and invasive dampness.
An effective dehumidifier guarantees dryness in the basement, preventing proliferation of dust mites and mildew. Most contemporary dehumidifiers are sold with air filters that keep the circulated air free of allergy-causing pathogens.
Understanding Basement Temperature Dehumidifier Functionality
In addition to conventional standard temperature dehumidifiers, a new range of low-temperature basement dehumidifiers is also available on the market. They are often referred to as basement temperature dehumidifiers because conventional dehumidifiers aren't popular for preventing frost in the basement.
Low-temperature basement dehumidifiers are capable of preventing crystallization of moisture in the basement area. Winter frost compromises the structural stability of the basement walls. Freezing water creates hard-to-detect cracks in the concrete surfaces.
Most low-temperature basement dehumidifiers offer innovative features such as frost guard warnings along with alarm settings for overflow. Standard basement dehumidifiers don’t offer such a wide range of options; however, they are an effective and budgeted solution for ensuring that your basement stays dry.
Ease of Temperature Settings
The latest range of basement temperature dehumidifiers are retailed with an automatic temperature display screen and humidistat. The displays regulates the overall temperature of the house. An effective dehumidifier can decrease the dependence upon air-conditioning and other room-heating devices.
During harsh winters, a dehumidifier can be cranked-up, making it handy for warming the entire house. The humidistat is used to adjust the humidity level. Its functionality increases by a certain percentage value every time the knob is turned. Temperature-maintaining dehumidifiers are commonly retailed with a guide explaining standard humidification/temperature settings for domestic spaces of varying sizes.
Understanding Basement Dehumidifier Retailed Choices
A dehumidifier has some basic components, like the fan and compressor that are standard across all models. These two components only vary in their size and overall capability to quicken the pace of drying the moisture. Dehumidifiers are retailed according to the area they can dry in a given period.
Most domestic basement dehumidifiers are offered with technical specifications of 1000 to 1400-feet square, the amount of area across which their effectiveness is guaranteed.
The ability of a dehumidifier to remove moisture is expressed in the number of pints it can remove. 50-pints means that the machine can dry nearly 50 pints of moisture per day. Most residential dehumidifiers are easy to compare in terms of the energy units they consume and their ability to function with low voltage power. The energy efficiency is often presented in the form of energy star ratings.
Dehumidifiers for larger basements are sold with the option of an accessory pump. The use of an additional pump is recommended if your basement is already struggling with moisture seepage and needs quick drying action.
Models with built-in pumps are slightly expensive, but they are more compact, easier to install, and occupy less space. You should also consider the drainage options which are offered.
Conventional choices include the bucket or the garden hose drain. They are easy to handle and have been in use for many years. The direct drainage method is slightly demanding to install, but this drainage system is concealed from common view and is recommended for aesthetic purposes. When deciding on a basement dehumidifier, you should ask the retailer about the washable air filters, which are often offered as free accessories.
Looking for a dehumidifier? Compare brands, types and prices with our Dehumidifiers Buyer's Guide.
