Basement Mold and Mildew Removal: A Guide Basement Mold and Mildew Removal: A Guide
Mold and mildew removal can greatly improve the atmosphere inside a home. These organisms are highly hazardous to health if left to flourish in any part of the house. Moreover, they may contribute to the deterioration of building structures and materials. These organisms can grow anywhere in your household and your basement is one of their most probable breeding grounds. There are several contractors that offer services on mold and mildew removal. These professionals use proven techniques and methods to ensure that infected areas are thoroughly cleaned. However, you may find that they also ask exorbitant amounts in exchange for their services. Fortunately, you may not need the help of these professionals to remove the mold and mildew that are accumulating in your basement. You can do the task yourself.
Scrub the Basement Floor and Walls
Getting rid of mold and mildew may require scrubbing the infected areas with a heavy duty brush. You may also need to purchase certain types of mold and mildew removal products. There are many commercial products out there that you can use in cleaning and disinfecting your basement walls and floors. If you do not want to make a purchase of these products, you may make your own mold and mildew removal solution. The solution may be composed of baking soda, bleach, vinegar, and hydrogen peroxide mixed together.
These products can be applied to the infected area moderately to help loosen and soften the overgrowth of mold and mildew before brushing. If you have a large basement, you may need the help of your family members to do this so you can easily finish the job. Cleaning a large basement may take time especially when the mold and mildew have stubbornly clung to the different parts of your basement. Always remember to wear safety gear such as gloves and safety masks before proceeding with the task of removing the overgrowth of molds and fungus.
Get Rid of Moisture
Moisture is the main culprit behind the formation of molds and mildew. Getting rid of the moisture, therefore, is a crucial step to successfully eliminate the presence of mold and mildew in your basement. Look for the source of dampness in your basement and try to get rid of them. Likewise, always keep your basement dry. Avoid dumping any wet materials on it. Perform regular cleaning and scrubbing, making sure that no amount of moisture is left to cling to the basement surfaces for a long time.
Regulate the Basement Temperature
Mold and mildew growth is often common in areas where there is higher humidity levels. Try to regulate the temperature of your basement. Keep its temperature less humid as much as possible. You may install ventilation equipment, such as a dehumidifier or an exhaust fan or ventilation fan if possible. These equipment may help keep the temperature of your basement at a low level, discouraging the re-growth of any type of fungus in the area.
The best thing you can do to ensure effective mold and mildew removal in your basement is prevention. As much as possible, keep your basement clean and free from any form of moisture. Treat mold and mildew immediately at their early signs of growth and do not wait for them to accumulate in number. The more they have grown and spread throughout your basement, the more difficult it will be to remove them.
