Basic Bathroom Drain Plumbing Basic Bathroom Drain Plumbing
A commercial drain unclogger
A plunger
A hand auger
A wet rag
Dealing with a stopped up bathroom drain is a common headache among household handymen. Fortunately, unclogging that stubborn bathroom drain can be a piece of cake, particularly if you're armed with a thorough set of instructions and the right set of easily-obtainable tools. So the next time you find yourself at the mercy of a clogged bathroom drain, don't outsource the job to a high-priced plumber, just consult this handy guide to learn everything you'll need to know about unstopping bathroom drains.
Step 1 - Try a Commercial Drain Unclogger
If you don't feel like exerting the strength required for plunging a clogged bathroom drain, you may want to incorporate the aid of a commercial drain unclogger, such as Drano. Should you choose to use these products, take care to use them sparingly, as they contain an assortment of chemicals that are liable to eat away at your drain pipes if applied in mass quantities. If this method of drain unclogging proves successful, your clog probably wasn't very severe. Also, if the clog was in your sink or tub drain, be sure to run the hot water before using the device again.
Step 2 - Use a Plunger
For more serious clogs, you may require the aid of a plunger. Make sure to stop up your sink, tub or toilet's overflow opening with a soaking wet rag in order to ensure that the full force of your plunging is concentrated directly on the source of your clog. If you're attempting to plunge a clog found in the drain line of your sink or shower, fill the tub or sink with a small amount of hot water, then proceed to give the clogged drain a thorough plunging. As you no doubt know from experience, plunging can be a very physically taxing exercise, so when engaged in this task, make a point of taking periodic breaks whenever you feel yourself becoming tired. Once again, if the clog was found in your sink or tub drain, make sure to run the hot water before using the device.
Step 3 - Pull Out the Source of the Clog With a Hand Auger
If Drano and plunging do not provide you with results, it's time to give the hand auger a try. This handy little tool helps extract clogs as opposed to driving them downward, like plungers. Start this step by inserting the hand auger's cable into your sink, tub or toilet's overflow opening and continue moving it downward until it's latched onto the source of your clog. Once the cable has snagged the clog's source, gently attempt to jostle it loose. Should this fail, you will need to carefully rotate the auger into the device's overflow opening and, after coming into contact with clog's source, jostle it loose and pull it out.
So there you have it. Next time a clogged bathroom drain finds its way into your home, you'll be ready to tackle it without hesitation.
