Bathtub Plumbing Mistakes to Avoid Bathtub Plumbing Mistakes to Avoid
Mistakes in your bathtub plumbing designs and projects can be quite costly. If you do not want to see your money go down the drain, you need to know the common mistakes that people make when installing or repairing plumbing systems for bathtubs. This way, you can avoid them before you even start your project.
Using Wrong Pipes
One bathtub plumbing mistake that many homeowners make when embarking on a DIY project is buying the wrong size of pipes. To avoid this hassle, you need to determine the right size of pipes that you need before starting the project. If you are not sure about the size of the pipes, you should seek the help of an experienced plumber. Remember, using the wrong pipe size can result in future problems, such as clogging and leaking.
Not Having the Right Equipment for Bathtub Installation
In order to make the process of bathtub installation or repair smooth and without problems, it is important to prepare everything that you need to complete the project beforehand. Remember, using faulty or inadequate equipment can result in injuries or improper plumbing installation. Moreover, try to lay down all the tools in a place that is easily accessible. Doing so will save you a lot of time and effort.
Ignoring Local Building Codes
There are bathtub plumbing codes that you need to follow in order to keep your home safe. You need to understand that each state or city has its own set of rules and restrictions. To ensure that you are not breaking any building codes, you should know which ones are being enforced in your locality. You can surf the Internet to find your local building codes or simply ask questions from the pertinent agency.
Failing to Cut Water Supply During Installation
Installing a bathtub may look simple on paper. However, if you do not have any experience in performing plumbing jobs, you might commit mistakes that are as simple as failing to turn off the water valve before starting the project. Failing to do this simple task can result to flooding in your bathroom and spending a lot of time cleaning wet furniture and floors.
Failing to Test Assembly Parts
It is always a good habit to check if all the things that you installed fit together perfectly before the final assembly. You do not want to apply pipe cement and find out that a washer is out of place. This fatal mistake can prolong the number of hours needed in order to finish the project. Worse, it can also force you to repeat the process from the beginning.
Not Testing For Leaks
After completing your bathtub plumbing project, make sure to test for leaks. Once all the adhesive applications have dried out, open your water valves to see if the pipes and drains are tightly connected. It is easier to fix leaking problems immediately when the installation is new, rather than discover later on that you have leaks every time you get out of the tub.
