Benefits of a Metal Staircase
Metal staircases are a favorite for many homeowners. They make a suitable alternative to the wooden or stone stairs. Some benefits are given below.
Durability
Metal has a higher resilience and durability over wood and stone staircases. If constructed from metal, staircases will last several years. They have a high resistance to various types of damage. Breakages, splits, warps and dents are unlikely on a metal staircase, even under high pressure.
Versatility
Metal gives you more design options than other materials. This is partly because of the high flexibility of the material. It can be cut and welded into various designs. You can achieve spiral, straight or curved designs easier with metal. Simple or elaborate designs are both easily achieved with metal.
Ease of Installation
The high flexibility of metal adds to ease of staircase installation. This helps to keep construction costs within a reasonable budget and enable a cost-effective installation. Yet, once installed, a metal staircase adds value to your home.
Low Maintenance
Not much care is required for metal stairs to keep them in good condition. The staircase isn’t affected by high humidity or temperature fluctuations. Squeaks hardly manifest even on heavily used staircases. You needn’t seal, varnish or paint a metal staircase to maintain its fine appearance.
