Benefits of Porcelain Tile
tiles
Porcelain tile offers a range of advantages that have contributed to its booming popularity. It is not only stronger than regular ceramic tile, but it is also more resistant to moisture and frost. Porcelain tiles are ideal for use in both high-traffic areas and outdoors. Many stores sell discount porcelain tiles, which makes them attractive from a monetary point of view.
Main Benefits
Porcelain tiles are a type of ceramic tiles but made from finer, denser clay, fired at very high temperatures, and manufactured under high pressure, which gives them added strength against fire and chemical damage but also makes them scratch-resistant. Porcelain tiles are available in an unglazed, matte, and highly polished finish. Lower moisture absorption makes them more resistant to stains and easier to clean. Porcelain tiles do not require sealing. They can easily be cleaned with a damp mop or cloth, and they are available in many different styles and designs.
Installing Porcelain Tile
With proper planning and the right materials, you can easily install porcelain tiles on your walls or floors. Before installation, make sure the floor is clean, even, and strong. Mark the center of the installation area and place the tiles in a dry run to help you determine whether you need to make changes in the layout. Mix the mortar and start laying the tiles. Plan your working pattern so that you do not have to walk over newly laid tiles. Grout the lines between the tiles, and wipe excess grout with a damp cloth.
