Benefits to Foil Backed Insulation Panels Benefits to Foil Backed Insulation Panels
Foil backed insulation is the result of foil being placed on foam board. It is used to insulate walls and floors of the home. Read on to learn some of the benefits associated with this type of insulation.
Strength
Foil backed insulation provides strength to the overall internal integrity of the home. Many have used this type of insulation to strengthen flimsy walls.
Thermal Barrier
Unlike other types of insulation, foil backed insulation does not absorb heat. Instead of absorbing the heat, it reflects it, keeping the home cool in the summer and warm in the winter. In the attic, foil backed insulation will help ward off radiant heat from the sun.
Easy to Install
This type of insulation is very easy to install. You can trim it with a simple pair of scissors and attach it to the walls and ceiling with a staple gun or some finishing nails.
Light
Many insulation products are heavy and bulky or require special machines, but foil backed insulation can be installed by one person. It is very lightweight, which makes it easy to handle.
Maintenance-Free
Foil backed insulation can last the lifetime of the home as it won't disintegrate. There is no special maintenance required.
