Best Roofing Options for Your Climate
Homeowners can choose across various roofing options. Roofing is one of the most basic building components that protects against weather conditions and defines the external appearance of a house.
Roofing Considerations
Some roofing options seem to have become synonymous with different kinds of buildings. For instance, most of the residential buildings have sloped roofs whereas most commercial buildings are constructed with flatter roofs. However, there are no rules to direct the roofing options for a homeowner.
For most homeowners, the ease-of-repairing and lower maintenance costs are the major deciding factors apart from the roof’s ability to handle typical, climatic challenges. It should be understood that among household surfaces needing repairs and continued maintenance, roofing is one of the major considerations.
An ideal domestic roofing option should be able to combine easy handing, minimal preservation costs and some degree of aesthetic appeal. Some commonly-used roofing options have been explained below:
1. Rolled Roofing
Rolled roofing is among the cheapest of roofing options. It is more suited for covering flat roofs. Such roofs often incorporate the use of asphalt shingles as a roofing material.
Advantages
The roofing material here is easily available and offers easy installation. Rolled roofing also presents easy repairs. The roofing material is available in the form of standard sizes at hardware stores. The replacement bits can be installed with basic, household tools. The roofing material here is essentially a small rolled-over form of coated asphalt.
Maintenance Features
The roofing material is fastened to deck of the roof with nails and roofing adhesive—both materials are easily available and quite affordable. Such repairs can be easily tendered without employing professional help. If the roof has a slight slope, the rolled asphalt material can be used in greater thickness to reduce chance of leaks and maintain proper drainage—this underlines dexterity of rolled roofing materials.
Some Issues
This roofing material isn't very durable. Though it is known to last for years, it is not recommended for high-rainfall areas. Consistent moisture can dampen the roof decks of rolled roofing, adding-up to the annual, maintenance costs. However, for moderately dry/cold regions, this roofing choice is quite useful. Further, the used/weathered bits of rolled roofing can be easily manipulated into temporary roofing for the shed or garage—a substantial cost saving.
2. BUR or Built-up Roofing
Built-up roofing can be considered as the mid-range/budgeted choice in the household roofing niche. It is mainly applicable to flat or slightly-sloped roofs. Such roofs often use roofing tiles as the roofing material.
Advantages
It offers greater durability than rolled roofs. This is mainly because of the fiberglass roofing material that offers better resistance against moisture and external, weather elements. Often BUR roofs are further strengthened with resins of bitumen or coatings of tar and asphalt. This makes BUR a more durable choice among high-rainfall/snowfall areas and homes exposed to extreme heat.
BUR roofing systems aren’t the easiest-to-repair. Repairing such a roof requires more than the average level of tool-based skills. However, their extended durability means that the maintenance costs are rather minimal and repeated repairs aren’t needed.
3. Spray Roofing/Rubber Roofing
Spray roofing uses a synthetic roofing material called sprayed polyurethane foam or SPF. Spray roofing installation is usually not recommended as a part of self-to-do projects, i.e. it needs professional application.
Advantages
This is among the most recommended roofing options for homeowners struggling to insulate their homes against extreme cold or moisture seepage. Widely regarded as the most durable of the contemporary roofing options, spray roofing has established itself as the most resilient roofing option.
The roofing material is very durable and offers years of maintenance-free performance. However, spray roofs cost substantially more than the other options explained above. It is best advised for people who are looking to invest in a long-term roofing solution wherein they don’t mind paying a bit during the installation phase in favor of negligible maintenance costs for many decades.
