Best Wood Stair Tread for Snow Best Wood Stair Tread for Snow
Wood stair tread can be used in or outdoor, or in a home or commercial building. For snow conditions, the wood stair tread will need to be non-slip and if possible, heavy duty. Non-slip wood treads usually come with a life time warranty and are inexpensive. The strips on these treads will prevent slipping and ensure safety. They are perfect where there will be a high amount of traffic where ice, water or snow can be dangerous and cause slipping.
Rubber Stair Treads
Rubber stair treads makes walking on wood stairs safe after snow has fallen or in icy environments. The rubber stair tread can come in a heated form which is made up non-slip UV protected rubber. It is a durable tread and can even be left out for the winter.
Adhesive Stair Treads
Adhesive stair treads secure your stairs safely to each step taken. Adhesive stair treads install easily by cutting the material (made of Velcro) to the specific size for the stairs, and sticking to the hook side to the back of the stairs. These can be removed and reapplied when necessary. They prevent slipping that may occur as a result of snow, water and ice.
