Build a Free Standing Glass Mirror Frame
Lumber
Brass decorative wood screws
Threaded hex drive screws
Threaded sleeve nuts
Dowels
Dowel centers
Wood glue
Saw
Hand plane
Jigsaw
Router
Mallet
Nail
Rebate bit
Straight edge
Measuring tape
Pencil
Straight bit
Rounding over bit
Round bottomed spokeshave
Pipe or sash clamps
Stain or finish
Clear coat
Stapler
Building a hand made free standing glass mirror frame is worth the time it takes. Once finished, you will have a quality piece of work that will last years and can be passed down generations.
Step 1 - Cut Frames
Cut 2 end frames using hand or electric saw. Next, cut the mirror frame.
Step 2 - Remove Marks
If the wood has machine marks, remove them using a hand plane.
Step 3 - Draw Shape and Cut
Set the 2 end pieces face down and draw out the curved shape you want. Using a jigsaw, cut out the shape, tapering the front. Make sure to cut slightly outside the lines. Use a round bottomed spokeshave, cut to your line.
Step 4 - Round Edges and Mark Center
Round off all of the edges except bottom with router. The position of the frame brace is on the center line and flush with the bottom, mark it.
Step 5 - Drill Holes
Clearance holes must be drilled through end frames. Make the hole size larger than the shank diameter of the screw so it drops through.
Step 6 - Sand, Screw, and Glue
Round over along 2 top edges of frame brace and sand both faces. Screw and glue it into position.
Step 7 - Check Dimensions
Double check internal frame dimensions to make sure the mirror frame pieces will fit.
Step 8 - Drill Dowels and Fit
In each end of the mirror frame pieces, mark out 2 dowels. Use dowel drill for drilling. On a flat surface, transfer dowel positions onto side pieces using dowel centers. Squeeze the pieces together. The dowel centers guide you.
Step 9 - Drill and Glue Sides
In side pieces, drill holes. To hold excess glue, the holes should be half the length of the dowel. Squeeze glue into holes, spread around surface of hole using a long nail. Use a mallet to drive dowels into holes.
Step 10 - Assemble the Frame
Squeeze glue into remaining holes and assemble the frame. To avoid damage to the frame, use scrap material between frame and pipe clamps when assembling. Set aside clamped frame and let dry.
Step 11 - Sand
Remove the frame from the clamps. Round the edges and sand the entire frame.
Step 12 - Route the Rebate
Set up the router. Use a rebate bit and rout rebate on the inside of the frame. Route the second rebate. Use the straight edge as guide.
Step 13 - Drill Pilot and Clearance Holes
Drill a pilot hole for screw-in nut at center point on each long edge of mirror frame. Drill clearance hole on each side of end frame for the machined screw.
Step 14 - Attach Frame and Base
Use a washer between the upright and the mirror frame and tighten the screw. Make sure there is enough clearance between mirror frame and upright. If there is not enough clearance adjust the frame.
Step 15 - Finish the Wood
Finish and seal the frame in the wood coating desired.
Step 16 - Have the Mirror Fitted
Take the mirror frame to a local glass fitter to have it fitted.
Step 17 - Apply Backing
Apply MDF backing to the top rebate and attach to frame with staples.
