Build a Homemade Boat Lift
4 steel I beams (2x10-foot and 2x5-foot beams)
Cutting torch
2 flat steel plates
Welding machine
Drill press
Steel eyebolts
Nylon line
2 sheave blocks
Cutting torch
2 flat steel plates
Welding machine
Drill press
Steel eyebolts
Nylon line
2 sheave blocks
Building a homemade boat lift is far less expensive than buying one. Here are some steps to help you build a boat lift that is functional and affordable.
Step 1: Fix the Beams
The first thing that you will have to do to is fix all four “I” beams together. Use the cutting torch to cut 45-degree angles on one end of all four steel beams. Weld the 5-foot beams to the 10-foot beams at the edges which have been cut. When all four beams are welded together, it will form the davits. This will look like a rectangular framework.
Step 2: Weld the Plates and Eyebolts
With the drill press, drill ½-inch holes in all the corners of both the steel plates. The steel plates need to be about 5 inches in length and about ½ inch in thickness. When you have drilled holes in the flat steel sheets, weld one plate to the bottom of each 10-foot beam. When this is done, weld steel eyebolts on the end of each of the 5-foot beams. These eye bolts are meant for suspending the riven tackle.
Step 3: Attach the Davits
Once you have all these in place, you can bolt the davits to the pier or walkway of the dock. It is important that the davits are one boat length apart, according to the length of your boat.
Step 4: The Finishing Touches
Reeve a twofold purchase with the nylon line in the blocks. Using the line, hang the sheave blocks from the eyebolts made on the davits. Screw one eyebolt into the structural member in the front, or stem. Screw another steel eyebolt in the after structural member which is also known as the transom frame or main frame of the boat.
Your boat lift is now complete. Bring your boat along the pier or dock walkway and attach the boat falls to eyebolts located on the rear and front of the boat. Using the falls, you can raise the boat onto the davits, protecting it from water-related damage.
