Build A Platform Bird Feeder In 6 Steps
Drill and drill bits
Screwdriver (Philips head)
Four 16-inch pieces of 1 by 2-inch cedar for corner posts.
Two 24-inch length pieces of 1 by 2-inch cedar for the feeder's side rails
Two 21-inch length pieces of 1 by 2-inch cedar for the feeder's shorter side rails
One piece of 3/4-inch Marine Plywood, 2-foot by 2-foot square
One piece of 3/4-inch Marine Plywood, 2 1/2-foot by 2 1/2-foot square
Twenty 1 1/2-inch wood screws
Eight 1-inch wood screws
A small bottle of exterior rated wood glue
One 4-foot by 4-foot pressure treated wood post
Shovel
Bag of quick setting cement
If  you have basic woodworking skills, you can build a platform bird feeder in just a couple of hours. Here's how.
Gather the tools and materials you'll need before beginning. Use weather resistant woods like cedar, cypress or oak, as they will last longer. Cedar is the easiest and least expensive weather resistant wood to work with. The feeder may be mounted on a post, nailed to a deck rail or even set out on a table or other flat surface.
Step One-Assemble and Dry Fit Pieces
Once you have all your pieces cut, dry fit them by placing them on the platform without glue or screws, to make sure the rails don't hang over the sides of the platform. The rails should all fit flush with the edge of the platform. Trim the sides if needed after dry fitting.
Step Two-Glue Rails to the Platform
Glue the 1 by 2-inch side rails to the edges of the 2-foot by 2-foot platform, making sure the 2-inch side lies flat against the platform. Secure the rails to the platform with two 1-inch screws.
Step Three- Drill and Assemble Corner Pieces
Once your rails have been attached to the platform, pre-drill two holes in each corner of the plywood base for your 1 1/2-inch screws. Set one of your 16-inch pieces vertically over the hole. Using your pre-drilled platform holes, drill holes in the vertical rail as well. This will keep the wood from splitting when you screw it to the platform. Repeat this for all four corners. Glue each post and screw it to the platform.
Step Four-Attach the Top of the Feeder
Center the 2 1/2-foot top piece of plywood on the four vertical posts you just attached to your base. Drill two holes in each corner, making sure the holes go into the vertical corners. Secure with glue and 1 1/2-inch wood screws. Your platform feeder is now finished. You can seal, stain or paint the wood, or allow it to weather naturally.
Step 5-Secure Your Feeder to Post or Rail
Secure the feeder to a 4-foot by 4-foot pressure treated wood post. Other options include nailing it to a deck railing on your deck or attaching it to a fence rail or level tree limb.
If you've decided to secure the feeder to a post, use four 1 1/2-inch wood screws to attach it to the 4-foot by 4-foot post. Dig a hole for your post. Make sure the hole extends at least a foot below the frost line.  Set the post in the ground, making sure it's plumb and level. Secure it with a piece of scrap lumber so the post remains plumb while you mix your cement. Mix cement and pour it into the hole around the post. Allow the cement to set for 24-hours before removing your stablizing piece.
Birds are messy eaters, so plan on using a paint scraper and whisk broom to clean old seed off of the feeder at least twice a month.
