Building a Garage Pole Barn: Mistakes to Avoid Building a Garage Pole Barn: Mistakes to Avoid
When building a garage pole barn, there are a few common mistakes that people make. Here is a small guide that can help you avoid those mistakes and get through the process painlessly.
Uneven Ground
One of the biggest mistakes is to not check out and level the ground before beginning. You need to make sure that the surface you are building on is strong enough and level enough to work on and hold the entire garage pole barn.
Not Considering the Material
Considering the type of material that you use is important. When using wooden poles, you need to make sure that they are about 10 inches or so apart from one another. However, if you are using metal, you may want them to be a little closer together.
Not Getting the Whole Picture
Many times, people begin the set up and forget about the entrance way until they have already begun building. Be sure that you are planning the entire design in advance and know the dimensions. This can not only help you with avoiding any major building problems, it can also come in handy when you are ordering the material and supplies for the project.
