Building Roof Trusses for Your Garage Roof: Mistakes to Avoid
When building roof trusses, there are a few common mistakes that you will want to avoid. Here are some guidelines to help you get through this project quickly and and mistake free.
Watch the Thickness
The thickness of the roof trusses are extremely important. You want to make sure that the weight the has to be supported is taken into consideration when you are cutting for the roof trusses. Having roof trusses that are not thick enough can actually cause a lot of serious problems down the line for your garage as well as what you have in it if they can't support the weight.
Use the Proper Screws
Not only do you want to watch out for the type of screw that you use, either galvanized or deck screws, you also have to watch out for the length. A good length for roof trusses is about an inch and a half screw. This way you know that they will be held together in a sturdy way, but not too big that it splits the material when being attached.
Leave an Overhang
The overhang is not something that most people think of right away, but it is necessary. Be sure to leave an overhang as you are working on building roof trusses for your garage.
