Can a Carport Bear the Weight of a Residential Solar Panel? Can a Carport Bear the Weight of a Residential Solar Panel?
If you need a place to put a residential solar panel, one of the options that you may have is to put it on top of a carport. It is possible to put a residential solar panel on top of one, but you must make sure that it is not too heavy. You must have a fairly stable carport to work with.
For the solar panel to be successful, keep in mind that it needs unobstructed access to plenty light. The carport can not be shaded by trees or a building for a majority of the day.
