Can a garage door spring be too heavy for the garage door? Can a garage door spring be too heavy for the garage door?
A garage door spring can be like a loaded weapon when it is fully extended. If you are unfortunate enough to be near a garage door spring when it gives way, then you are probably going to sustain some sort of serious injury. Replacing garage door springs is something that should be done by a professional. The springs are either extension or torsion, and most doors have both kinds. If a spring is not the right length, it will either not allow the door to open properly, or it becomes a hazard when it is opened. A garage door spring is not usually too heavy for the door, but it can definitely be the wrong length.
