Can a Granite Tile Counter Chip? Can a Granite Tile Counter Chip?
If you have a granite tile counter, it could chip at some point. Granite is a natural stone and it is very strong. When you drop a heavy cast-iron skillet on the corner of your granite tile countertop, there is a good chance that it could crack or break. It is also possible to put too much weight on the corner of the counter, breaking the tile. When you are working around the counter, you need to be very careful and set everything down as gently as possible. If you crack granite, the only way to fix it is to replace a tile.
