Can I install tile over laminate kitchen countertops? Can I install tile over laminate kitchen countertops?
It is possible to install tile over the top of laminate kitchen countertops. To complete this project, you need to make sure that the laminate is adhered firmly to the cabinets. Before doing this, you will need to rough up the surface of the countertop. You need to be able to get down into the other layers of laminate before you can attach the tile with the adhesive. As long as you do this, you should be able to install any type of tile that you want. Granite, ceramic and porcelain are all good choices for this application.
