Can I install vinyl siding over existing concrete siding? Can I install vinyl siding over existing concrete siding?
Although concrete siding has its advantages over other types of siding, its disadvantages may prompt you to consider other sidings such as vinyl. What if, after installing concrete siding, you decide you would like to try installing vinyl? Is it possible to install vinyl siding over concrete?
You can install vinyl siding over concrete, if you're willing to pay the cost for installing it. You will need to first install furring strips, 1 ½ inch wood strips, and then install insect screening on the wood strips. Once the furring strips are installed, you can then use vinyl siding nails to install the vinyl siding.
