Can I mix baseboard heat with radiators? Can I mix baseboard heat with radiators?
There may be a problem in mixing baseboard heat with baseboard radiators, especially in old houses. Just ensure that the radiators are appropriately sized in line with the dimensions of your room and have a correct water flow. If you install baseboard radiators, you would need to see that the electric wiring is properly installed. However, baseboard heaters are currently considered to be a less costly option as they are run on a generally cheaper sort of energy (electricity), and installing new radiators is more costly than installing baseboard heaters.
