Can I reset a ceramic heater myself? Can I reset a ceramic heater myself?
To reset a ceramic heater, you have to reset and program the timer in the heater manually. Start by ensuring that there are no loose connections in the wiring, as those could cause the new settings you are entering to switch off and erase. Next, use the LCD display to scroll down the menu and reach the appropriate option and icon for resetting the timer. If the heater is preprogrammed by the manufacturer, use the manual override option to enter the new settings. Setting the clock is crucial at this stage, as the timer switches on or off based on the clock. Choose a 12- or 24-hour time format (whichever is most convenient to you) and adjust the settings accordingly.
