Can I use bow window treatments to fix an uneven bow window?
Bow window treatments help enhance the beauty and often fix the problem of an uneven bow window. If you have uneven windows that are spaced together, treat them as a single unit and use a single pelmet to cover the entire length. Alternately, you could use a curved track or valance to create the illusion of continuity. In case the windows are far apart, use the same treatment for them, keeping the height and length of the track identical.
You can also use Roman blinds for sets of windows that vary in height. For the higher window, roll the blinds down in a way that only the top portion gets covered. This makes the smaller window appear to be similarly sized.
