Can You Leave an Electric Fireplace on Overnight?
There is no problem with leaving an electric fireplace on all night However, it is important to remember some basic safety measures when using such heaters. Electronic heating allows electrical energy to be converted into heat. The electrical resistor helps to heat the heater.
Cons of Leaving the Electric Fireplace on Overnight
The only major issue is the electricity bill that will add up for the full month. These fireplaces require a lot of electricity and will not help you in saving money on your power bill. Therefore, most families opt to use an electric fireplace on a partial day basis.
Tips for Leaving the Electric Fireplace on Overnight
Modern electric fireplaces have many additional features like automatic shut-off switches, which make them less risky to use at night. The heater shuts down automatically once the room is heated. Make sure all fabric, including clothing, rugs, drapes, furniture and bedding is kept at least three feet from the electric heater. There's a potential for a fire to start if any of these fabrics come in contact with the heater. Remember to keep an electric fireplace far away from water sources.
