Car Puncture Repair Basics Car Puncture Repair Basics
Car puncture repair is something that you may have to worry about from time to time. You will find that there are several things that could cause a puncture to happen in your vehicle. You could be at a store and a grocery cart could slam into your vehicle. If the cart is going fast enough and the right part hits your vehicle, then you could have a pretty ugly hole on your hands. It is also possible if your vehicle happens to come into contact with a curb that is too high. This could also cause a hole. Rust could also create holes in your vehicle. There are several things that could cause this to happen. Whatever the cause, you will find that it is important for you to be able to figure out the best way to fix the problem without having to break the bank.
Cover Puncture
The most important part of fixing a hole in your vehicle is to cover the puncture up. Usually a bondo will do the trick. This is a type of putty that you will put over the hole. You will do this if the hole is not very big. If the hole is too big, then welding will be necessary. If you do not know how to weld, then you may have to end up taking it to a professional that can do this task for you. However, if you are working with a smaller puncture, then a bondo will work well for you. It is important that you get a kind that will work for the size hole that you have. Make sure that you read the directions carefully before you even begin. If the directions are not followed as they should be, then this could end up causing more damage than what is already there.
Sand
Once the bondo has been added and you have allowed the allotted time for it to dry, then you will need to sand it down. Make sure that the putty is completely dry before you attempt to sand it. The directions will be able to tell you how long it will take to dry. The conditions that the vehicle is in may have an effect on dry time. Conditions such as weather and temperature as well as if the sun is beating down on it will have a lot to do with how long it will take for it to dry. Make sure that you sand it down completely before you move on to the next step. You will know that you are done sanding when the surface is smooth.
Priming
Once you have successfully sanded down the area and it is completely smooth, then you are ready to begin priming the area. Make sure that you do this in a well ventilated area and that you follow the directions carefully. Add the necessary amount of coats, remembering to give it time to dry in between each coat before applying a new one. Once the necessary coats have been applied you are ready to paint the area.
Cover Puncture
The most important part of fixing a hole in your vehicle is to cover the puncture up. Usually Bondo will do the trick. This is a type of putty that you will put over the hole. You will do this if the hole is not very big. If the hole is too big, then welding will be necessary. If you do not know how to weld, then you may have to end up taking it to a professional that can do this task for you. However, if you are working with a smaller puncture, then a Bondo will work well for you.
Sand
Once the Bondo has been added and you have allowed the allotted time for it to dry, then you will need to sand it down. Make sure that the putty is completely dry before you attempt to sand it. The directions will be able to tell you how long it will take to dry. The conditions that the vehicle is in may have an effect on dry time.
Priming
Once you have successfully sanded down the area and it is completely smooth, then you are ready to begin priming the area. Make sure that you do this in a well-ventilated area and that you follow the directions carefully. Add the necessary amount of coats, remembering to give it time to dry in between each coat before applying a new one. Once the necessary coats have been applied you are ready to paint the area.
