Cast Iron Bakeware
Cast iron bakeware has been used for many years, and it is still extremely popular today. Here are a few things to consider when purchasing cast iron bakeware.
Absorbing Heat
One of the unique features of cast iron bakeware is that it absorbs a great deal of heat when cooking. This contributes to the material's superior heat distribution, but because of this, the handle and every part of the baking dish will be very hot to the touch. This means that you need to make sure to use a mitt or a glove and make sure that you do not touch it when it is hot.
Health Benefits
Using this type of bakeware can actually provide you with health benefits. When you cook with cast iron, it puts small amounts of iron into the food that you are cooking. This helps you avoid an iron deficiency and stay healthy.
Cleaning
When you buy this type of bakeware, you have to be very careful that you clean it properly. This type of material cannot be put into a dishwasher, as it can damage the finish on the surface. Cast iron bakeware has a seasoning that acts as a protective finish on the baking surface. Therefore, you should typically only hand wash the bakeware.
