Ceramic Fuse vs Glass Fuse
1 hours
Beginner
- 5
If you need a new fuse and can’t decide between a ceramic fuse and a glass fuse, then check the pointers below. Knowing the pros and cons of both the ceramic fuse and the glass fuse will help you make an informed decision on which is best for your particular needs.
The Benefits of a Ceramic Fuse
The breaking capacity of a ceramic fuse is important because it defines the amount of current that can be stopped by the fuse. The capacity of a ceramic fuse is higher than any other fuse. This means that ceramic fuses can be used in circuits that have a higher current. Fuses made of ceramic also offer protection against overheating.
The Cons of a Ceramic Fuse
Ceramic is very delicate and can easily be smashed. This is a disadvantage as you must be very careful when handling your fuse.
The Benefits of a Glass Fuse
Glass fuses have been used for many years. They are a tried and tested method of fuse provision. They allow you to carry out the inspection of fuses directly, giving an immediate response. They are small and compact. You can purchase fast-acting glass fuses which provide you with additional protection.
The Cons of a Glass Fuse
The main disadvantage of glass fuses is that they have a lower breaking point than a ceramic fuse. There is also a possible time delay when using a glass fuse. This reduces the reliability of your fuse.
You now know the pros and cons of both glass and ceramic fuses, which will make it easier to decide which one to use. Simply use the list to decide which will be most beneficial for you and make your purchase.
