CFL Bulbs vs LED Bulbs
Both CFL bulbs and LED bulbs are considered to be superior to the incandescent light bulb. However, when you compare these bulbs against each other, you are going to notice a few differences. Here are the basics of CFL bulbs vs. LED bulbs.
Cost
When you start to compare these two types of bulbs, one of the first things that is going to jump out at you is the cost difference. CFL bulbs are going to be much less expensive than LED bulbs. Most of the time, you can get a CFL bulb for 5 dollars or less. With an LED bulb, you should expect to pay at least $30 or $40. This big initial cost difference steers many people towards the CFL.
Lifespan
When you compare these two, you will also notice that the LED bulb has a much longer lifespan than a CFL. Typically, it is going to last at least 10 times as long.
Energy
LED bulbs also consume quite a bit less energy than CFL bulbs. Because of this, they are also cool to the touch after being on for a while. CFL bulbs get hot while they are on which could increase your cooling bills in the summer.
