Cheap Casement Window Installation Cheap Casement Window Installation
When you are preparing for a casement window installation there are several things you will want to keep in mind. If you are doing several windows, it can turn into a big project. If you want to try to keep it within a certain budget, you will have to do things correctly to avoid any extra costs. Here are a few tips to install your casement windows as cheaply as possible.
Take Detailed Measurements
One of the most important things that you need to do when preparing for a casement window installation is taking proper measurements. You need to get very detailed measurements of the width and height of the window frame. If it helps, you should take off the trim surrounding the window so that you can see exactly how big of a window you need.
Windows are usually a special order item and you do not want to measure wrong in this scenario. Many companies will not allow you to return windows if you order the wrong size. If all sales are final, you could end up wasting a lot of money on windows that don't fit.
Make sure that you take detailed measurements of every window that you are replacing instead of assuming that they are all the same. Even though they might look like they are identical, they can vary from a fraction of an inch. This makes it very hard to judge what the actual window size is without measuring it. Even if you have to double check every measurement, it can potentially save you a lot of money.
Shop Around
When you go to order your windows, you need to shop around. Prices can vary widely from one retailer to the next. Therefore, you need to do your homework and make sure that you are not overpaying for anything. The prices of the windows themselves are going to be the biggest factor when trying to save money. You do not want to skimp on quality, but you do want to get the best deal.
Install it Yourself
Plan on installing the windows yourself once they arrive. Window installers usually charge quite a bit for their services. It is not a complicated process and can be done by anyone with the patience to try.
Make Sure it is Done Correctly
Once you start the installation, you need to make sure that the job is done correctly. There is nothing worse than messing up a job and having to bring another contractor in to fix your mistakes. That will add a lot to the cost and ensure that you go over budget. Be certain that the windows are square, shimmed in tight, and caulked all around the edges. The window should fit in snugly and not allow any air around the edges.
