Cheap Way to Revitalize an Old Mattress? Top It With a Mattress Pillow
If you fall asleep within 10 minutes of sitting still during the day, then you may need a mattress pillow. Though the cause of your sleep difficulties may be medical such as sleep Apnea  (or trying to sleep with someone who has it), irritable leg syndrome, low grade aching, etc., it could also simply be...your mattress.
Before you run out the door to spend exhorbitant amounts of money on a new mattress, consider a mattress pillow, mattress topper or pillow top mattress pad.
The most important point to understand is that a mattress pillow cannot fix a hammock or crater  type mattress. The mattress that sinks in the center cannot be transformed into firm mattress with a simple topper application.
The Memory Foam Mattress Topper, created by medical professionals was originally designed to alleviate bed sores on patience who were required to spend most of their day in bed. It provides comfort by readjusting its form to fit the contours of the body without added pressure.
The Pillow Top Mattress Pad is a microbfibre mattress ideal for people who cannot enjoy feather filled toppers due to allergies.
The Polar Foam Mattress Topper has been designed to keep your body comfortably cooler with its unique air flow cushion form system.
