Choosing and Applying Drain Sealer for a Fiberglass Tube Choosing and Applying Drain Sealer for a Fiberglass Tube
When it comes to choosing the right type of drain sealer for your fiberglass tube, there are a few things that you may want to consider and keep in mind.
Choosing a Drain Sealer
To choose a drain sealer for your fiberglass tub, you will want to first check to see if the tub's instructions or manufacturer has any suggestions or a brand that is used most commonly. If not, the next best thing to do is speak with your local hardware store professional. They will most likely tell you that silicone is a great choice as a drain sealer.
Applying the Drain Sealer
Most of the time the sealer will come in a bottle and has either a brush that comes with it or you can squeeze it out. You will want to apply the drain sealer to the area that you are working on, all of the way around. You can then be sure to rub it in completely and wipe off any excess sealer so that it doesn't get on the tub.
If you are having any problems with this task you should either consult the manufacturer or you will want to speak with a professional. They can help to guide you in the right direction.
