Choosing the Best Basement Wall Panels for Your Basement
When you upgrade your basement or repair damage from a flood, choosing the right basement wall panels becomes very important. You can choose from several types and styles of basement wall panels. Each has its own good and bad points. This article explains the most widely used basement wall panels and their uses.
Plastic Basement Wall Panels
If you live in a moist climate, this basement wall system may be perfect for you. You may expect some moisture because your basement is underground, but in areas with high rainfall, a basements become extra moist as water seeps through the walls. This prolonged moisture can cause basement walls to crack, leading to leaks.
Plastic basement wall panels drain water into a system that is installed behind the panels. This system prevents water vapor from accumulating while maintaining a nice look on the basement walls.
Finishing Systems
The basement is a dead space to many homeowners, who limit its use to storage. Basement wall panels can easily change the scenario by making the basement livable and usable. Paneling systems offer both acoustic and thermal insulation.
Many basements are prone to elements which limit the use of the space. Mold and mildew grow easily in damp basements. Many pipes and electrical equipment which reside in the basement that can become damaged by extreme moisture. The foundation can also be in danger. A finishing system protects the basement from all of these risks and more.
Panel Living Systems
A basement can easily become a media center, a game room, a second living room, or even a man cave. None of these finishing options is possible without a panel living system. You can choose from many textures and colors to customize the space. The panels are resilient to moisture and are very durable. Most living system panels are up to the insulation code.
Wood Paneling
If you are looking to enhance an area while eliminating worries of moisture, wood paneling is a sound solution. Wood paneling is a durable, inexpensive compound material; furthermore, it’s easy to install. If you need to cover a special insulation, such as foam or fiberglass, wood paneling is a good choice.
Drywall Panels
Drywall is often used to finish a job quickly. You can tack it onto a wood frame and finish it with paint. It offers no resistance to the elements.
