Choosing the Best Chemicals for Your Pop Up Pool
Cleaning and maintaining your pop up pool is very important to keep your family healthy. Using chemicals to maintain your pool is crucial and you need to choose the right type of chemicals to prevent accidents. To help you choose the best chemicals for your pop up pool, here are some points that you need to consider.
Chlorine
Chlorine is one of the most commonly used chemicals to kill bacteria and algae in pools. When applied at the right quality, chlorine can kill most types of seen and unseen algae in your pop up pool. To clean your pop up pool and kill algae, you need to apply granular or tablet type of sodium hypochlorite. However, too much chlorine in the water can cause irritations, especially around the eyes, ears and nose so you should be careful when using this type of chemical in your pool. Since large amounts of sodium hypochlorite in the water can be harmful to humans and animals alike, make sure that nobody uses the pool for several hours after you apply the chemicals.
Algaecide
Algae are one of the most stubborn pool pollutants and it can make your pool smell bad. Some types of algae are visible while others are not so it is important to use algaecide from time to time to ensure that your pool is free from algae. Also, using algaecide can help keep your pool water clear and your pool walls and lining clean.
Although purpose algaecides kill almost all types of green and black algae, if may not be strong enough to remove other types of algae including the yellow variety. To make sure that your pool is free from harmful pollutants, check out what type of algae has infected your pool and choose the right type of algaecide.
When applying algaecide on your pool, pour the liquid on the different areas around your pool. Keep your pool pump running while you apply the liquid to make sure that the algaecide gets circulated in your pool. Since algaecides can irritate the skin, do not let anyone swim in your pool for at least an hour after you applied the chemical. Also, you need to vacuum your pool at least 24 hours after you applied the chemical to remove the dead algae from the water.
Pool Water Balancing Chemicals
Balancing the pH levels of your pool water is important to protect your pop up pool from damage and to prevent chlorine related irritations on pool users. Water balancing chemicals that reduce the concentration of the chlorine in the water can be handy if you want to swim a few hours after applying a large amount of chlorine on your pool. On the other hand, pool water conditioner can be very helpful in preventing the ultraviolet rays of the run from breaking down the sanitizers in your pool water. Note that chlorine-based water sanitizers react to sunlight and prolonged exposure to sunlight can make your sanitizer ineffective within just a few hours after application. To prolong the life of your chlorine-based water sanitizer, you may add pool water conditioner.
