Cleaning A Keg Tap Step-by-Step
Beer being poured from a tap
  • 1-2 hours
  • 0-50
When the party's over and it's time to clean up, don't forget the keg tap. It is important to clean the keg tap not only to keep it in good shape for the next party, but to ensure there is no bacteria lurking in it. Unfortunately, washing it out with water does not do the trick. Cleaning the tap may take a little time but it is a simple process that should be done after every use.
To make sure you have a great party in the future, you want to provide good beer and a sanitary environment. This article will give you a step-by-step guide as to how to clean your tap properly and efficiently so you can have a great time at your party and ensure your guests do as well.
Step 1 - Prepare Keg Tap Detergent
To begin cleaning the tap you will need to get keg tap detergent and mix it with water. Check with your local liquor store to see if they carry a cleaning kit for a tap. The instructions on the kit will tell you how much cleaning detergent and water needs to be mixed together. The mixture should be put into some sort of bottle that has a hand pump to produce the cleaning solution.
Step 2 - Get to the Insides
Group clicking together beer glasses
Find the tap's faucet and remove the knob. Once you have done that, you will need to put the knob, the faucet, and the hose that produces the beer, into a bucket.
Find the cleaning attachment in your kit and connect it to the faucet. Take the bucket with the other parts in it and place it under the main part of the keg. Then put the hose inside the bucket so the cleaning solution will be able to steam into the bucket.
Step 3 - Clean Throughout
You are now ready to pump the cleaning solution into the bucket. It is best to let the solution sit in the hose for a good amount of time to make sure that all bacteria is broken down. Your kit will tell you how long to soak the hose.
Take the bottle you used to pump the detergent and clean it thoroughly. Fill it with cold water (without any detergent) and pump the entire bottle of water into the hose. Use the other tools included in your kit, such as a wrench to unscrew the faucet and use the brush to clean out the keg and the faucet.
Step 4 - Rinse and Reassemble
Rinse all the materials with cold water and allow them to dry completely before reassembling the keg tap unit.
Now that your keg tap is clean, it can be put into storage to await your next party.
