Clear Your Clogged Sinks with Natural Products
Clogged sinks can become quite a nuisance if you have a lot of water sitting in your basin. These clogs are created through a wide variety of ways. Your sink can be clogged due to hair, food, and small particles falling into the drain. Freeing up these clogged sinks is usually done through the means of snakes, plunging, or harmful chemicals. Many times trying to unclog your drain through these methods will damage the pipes.
Keeping Sink Drains Unclogged Naturally
Before you get out the big guns of chemicals and tools you will want to spend some time with natural cleaning products. You will be amazed at what some of the things around the house will do for your clogged sinks. It doesn't matter if you have hair, food, or a piece of a toy that fell into the drain, some natural products will help you remove them for clean flowing drains.
Some Necessary Precautions
When mixing any type of solution together you should always adhere to some safety precautions. You should have some rubber kitchen gloves, a coverall for your clothes and eye protection. Mixing things together can cause splashing which can irritate your eyes. While nothing is toxic, some of the natural products can cause irritations to skin and eyes.
Vinegar Is a Staple for Clogs
Even if you do not cook with vinegar, it is a good thing to have it around in your pantry. Vinegar can easily get rid of a lot of different clogs, and is a great cleaner for tiles, rugs, and other wall or floor coverings. Having both distilled vinegar and white vinegar on hand will get you through a lot of clogged sinks.
Use Vinegar and Water
The first thing to try when you have a clogged sink or a tub is to mix a solution of vinegar and water. This solution is a combination of one part vinegar with five parts water. You can do this in a spray bottle, or some other container. Just make sure that whatever measure you use of vinegar should be used five more equal times for water.
White Vinegar and Baking Soda for Clogged Sinks
Another natural cleaning solution is to mix together some white vinegar with baking soda. Mixing these two components together will get a little messy so you want to make sure that you have your gloves, glasses, and coverall on. When the baking soda hits the white vinegar it will start to foam. So do not pour too much in all at once. Use a mixture of a cup of vinegar and cup of baking soda.
Cleaning Clogged Sinks
With either of the two solutions ready to go you can then remove the drain cover on your sink if it has one. They are usually only attached with a small screw. Pour the solutions into the sink and let them sit for 20 to 30 minutes. The vinegar will begin to work away at the clog. Run some hot water down the drain and let it set for a few minutes. If the drain does not clear, then use a plunger and carefully plunge out the drain. If this does not work, repeat the process a few more times.
