Cobblestone Walkway vs Gravel or Concrete
6-40 hours
Intermediate
- 200-5,000
Debating whether to install a cobblestone walkway, a concrete walkway, or a gravel walkway for your home but don't know which to choose? Balance out the pros and cons to help in your decision.
1. Gravel Walkways
If initial cost is a major factor in building a walkway, you can't beat gravel. Still, there are considerations that may make it less of a favorite. Take maintenance, for example. To keep gravel from your walkway from becoming spread and scattered on the lawn surrounding the walkway, you'll need some kind of retaining form.
2. Concrete Walkways
Concrete, for sure, requires the least maintenance. Although its initial cost is higher, it is a far better choice in areas of the country where snow and ice have to be shoveled off walkways. However, if your walkway is to be temporary, you'll have to break it up with a jackhammer when it comes time to remove it.
3. Cobblestone Walkways
Cobblestone is for the homeowner who cares more about style and décor. You can't beat cobblestone for class, and when you change the look of your yard, you can easily change the look of your cobblestones. They may require more maintenance because of the grass and weeds that can grow in these walkways, but if style and class matters to you, you may not care about the time spent to maintain your walkways.
