Common Problems With Wall Mount Faucets
Wall mount faucets are quite popularly used in bathroom and kitchen sinks. Although these faucets are indeed great, there are certain problems that may be encountered before, during and after installation. When deciding to purchase wall mount faucets, it is a good thing to know these problems and how they can be remedied. Here are some of the most common problems encountered.
Choosing the Right Type of Faucet
Not all wall mount faucets are great for the pre-installed plumbing inside the home. Before purchasing any faucet, make sure to investigate if wall mount types are best for the sink. Know that wall mount types require hole drilling as well as pipe bending procedures. If it is okay to drill holes in the wall without compromising anything, then these faucets are good enough. Always take into consideration the installation process before purchasing faucets.
Pipe Bending
During the installation of a wall mount faucet, it is necessary to bend the hot and cold water supply pipes tightly. This may come as a problem because metal pipes are hard to bend. One way to remedy this situation is to use a pipe bender or use flexible fittings instead.
Installing the Plumbing
Another potential problem when installing wall mount faucets is installing the plumbing. If the wall is made of concrete or is covered with tiles, it will be necessary to chip through the wall, the tile or the plaster in order to fit the pipes inside. After the plumbing has been installed, the pipe needs to be covered as well. This may lead to a problem in the future because if the pipe requires fixing, the wall may need to be chipped once again. One solution to the problem is to install the plumbing outside of the wall if the wall has an inconspicuous exterior. Another tip when installing the plumbing is not to cover the fittings behind the wall. Extend the pipe to expose the fitting outside of the wall. This will make repairs a lot easier.
Leaks
Leaks can be caused by a variety of factors. One such factor is when the washer has not been installed, is damaged, or is not secured properly. Dismantle the faucet to check the washer. If it is damaged, it needs to be replaced as soon as possible to save on water. Another factor is a loose connection. Check all fittings and connections for tightness. One sure way to stop leaks is to use Teflon tape on the male threads during installation. If tape does not fix the problem, pipe dope may do a better job.
Water Splashes
After installation, the water may splash excessively and may even spill to the floor. This may be caused by installing the faucet too high from the sink. A good one-inch gap from the faucet to the top of the sink is recommended because it does not allow the water to splash too much. If the faucet has been installed already, then a faucet aerator can solve the problem.
