Compare Vinyl Siding: Price & Ease of Installtion Compare Vinyl Siding: Price & Ease of Installtion
When creating a budget for home remodeling it is important to compare vinyl siding prices with other types of materials. These comparisons will not only show you what other materials cost, but also how much you can either save or spend on your siding. Price comparisons are important not only for the actual costs of the material, but for other costs such as installation and maintenance. All of these things must be considered for an accurate comparison.
Compare Vinyl Siding to Cedar
A popular form of siding that many people choose for a more traditional appearance is cedar siding. However, the cost of cedar may be too much for many budgets, especially if the home is quite large. For example, to side a 2,000-square foot home it will cost roughly $14,000. In some cases a homeowner can get the materials cheaper at outlet centers, but they must be careful about defects and discontinuations.
Cedar siding also carries another cost that is not included with vinyl siding. The cedar will have to be either stained or painted to protect it from the sun, ice, and other weather. This can add another $2,000 to the price of the cedar siding once it is installed. If you plan to do the installation yourself, you can save $3,000 to $5,000 depending on your location and size of house.
Compare Vinyl Siding to Fiberboard
Another common type of siding is fiberboard. This is a cement-based product that is used in a lot of homes that will have a stucco or stone exterior. The fiberboard can also be used by itself, but will need to be painted. The cost of this type of siding can be close to $12,000 or more when installed by a professional. Doing the project yourself will save you some money. However, it can be tricky to install correctly.
Vinyl Siding Costs
Besides being an easily maintained and durable siding, vinyl siding is also fairly inexpensive. For the same size structure of about 2,000 square feet of exterior space, vinyl siding can cost $7,000 to $10,000 depending on the quality of the siding. Solid core vinyl siding will cost more because of the added foam insulation. This is a wise trade-off though as the R-factor is higher and the home is better protected.
Comparing Ease of Installation
When it comes to installing the different types of siding available, vinyl siding is still one of the easiest. It does take a little more time to install vinyl siding onto a home because of the extra tracks and corner trim that are needed. Once that is taken care of, the siding is basically a cut-and-nail type of siding. Cedar siding is very close to vinyl in ease. However, you do need to take constant measurements, and level readings, to ensure that it goes on correctly. Fiberboard is the hardest of the three to install. You need to use mortar and ensure straight cuts on the cement board.
Vinyl Siding Hidden Costs
When it comes to vinyl siding, once the siding is installed, there are very few additional costs. You may need to replace some of the pieces after a hard storm, but there is no need to paint, stain, or use expensive cleaners or sealers.
