Concrete Kitchen Countertops: Pros and Cons
Concrete kitchen countertops are a great option if you are remodeling or building a new kitchen. Read on to learn about the benefits and drawback of concrete to determine whether this is the material that you will want in your kitchen.
Lasting Durability
The durability of concrete is unrivaled. You can be certain that using concrete in any area of your home, you know that it is going to last for years and years.
Easy to Mold
No matter the shape of your kitchen, even a custom design, you can easily mold concrete into any shape that you desire.
The Expense
Though concrete is not expensive to make, having pieces professionally molded and installed is very expensive. Doing the job yourself will save money, but it is a big job with a lot of potential for error.
Change in Appearance
One of the biggest complaints is that the concrete changes color after a few months. This is due to contact with water and the sealer wearing off from pots and pans.
Sealing Often
Concrete is very porous. You will need to reseal it often to keep it from getting permanently stained. Once a stain has seeped into the concrete, it is there forever.
