Concrete Path Molds: European Block Brick
If you are redoing your patio or walkway and are looking for a unique but easy concrete path, the European block brick is a great choice. The unique style brings a traditional yet cultural style to your own home. Here is a quick guide that can help you to decide if this is the right design for you.
Design and Style
The design of this type of concrete path is gorgeous and traditional. The bricks are smaller in size and they run in a smaller circle in the middle and then move out to bigger rings as the path grows. Typically the stone is a gray or dark blue color, however you can choose whatever color you want.
Cost and Availability
The cost of this design isn't high at all. You can find the materials at many hardware stores or you can order them on line.
Installation
Installing this type of concrete path mold is a little bit harder than many others but can be done on your own still. You will want to start in the middle and work your way out. Having an even center is the most important step because you will work off that design. The outside will thrive off the inside circle.
