Copper Backsplash: 3 Cleaning Tips
Installing a copper backsplash can provide you with a very durable and beautiful surface on your kitchen wall. Copper backsplashes can be very unique and give you a focal point in the room. However, you will have to clean them correctly if you want them to stay looking good. Here are a few cleaning tips for a copper backsplash.
1. Regular Cleaning
One thing that you will want to keep in mind when working with copper is that you need to regularly wipe it down. If you are cooking and something splashes up on the copper surface, you need to go ahead and clean it as soon as possible. Cleaning it before the substance dries can make a big difference. If you leave water sitting on the surface, it can leave mineral deposits and water spots to worry about.
2. Copper Cleaner
You can buy a commercially available copper cleaner to clean your copper backsplash. This is one of the safest options and you know it will work, as it is designed specifically for copper.
3. Home Remedies
You can actually make a nice cleaning solution for copper out of things that you have around the house. Put a teaspoon of salt in a cup of vinegar. Then add some flour to the mix and make a paste. You can leave the paste on the copper and then wipe it off.
