Corrugated Metal Roofing: Repair Mistakes to Avoid Corrugated Metal Roofing: Repair Mistakes to Avoid
If you need to repair your corrugated metal roofing, you should be aware of some common mistakes that can be difficult to avoid. Some of these mistakes can effect your health, while others can effect the ability of your roof to resist water or storms.
Avoid Safety Mistakes
One of the simplest ways to avoid accidents while you are repairing your corrugated metal roofing is to make sure that you follow health and safety guidelines. Always wear hand and eye protection when you are making this repair, and handle power tools carefully. Secure yourself to the roof by some means that can bear your weight, and tread carefully.
Avoid Tape Repair Mistakes
If you are trying to repair your roof using mastic, or a seam tape, making a mistake in the placement can make your leak worse. Seam tapes need to be installed along the full length of the seam, rather than just on the part which is leaking. If you make this repair mistake, water will be channeled along the repair, and will find the leak hole again. If you are using mastic, be aware that this will eventually dehydrate and crack, leaving you with a major problem.
