Corrugated Metal Roofing: Steel, Tin or Aluminum?
Corrugated metal roofing has come a long way from the days when it was only found on barns. Many homeowners are choosing to use metal materials for their roof. Metal is more durable than other materials, can be installed quickly compared to non-metal roofs, and will last a lot longer than traditional roofing systems. Choosing the right type of metal may be overwhelming. Here is some basic information that can help you pick the right roof for your home.
Aluminum
Aluminum is a lightweight material that is inexpensive and durable. Since it's lightweight, it will not need special structural reinforcement. Aluminum roofing systems will resist rust and corrosion, which makes it a popular choice in coastal areas. This type of metal is easy to form, which allows it to be used on almost any type of structure regardless of the architecture.
Steel
Steel is naturally a strong material. It can resist high winds, making it a great choice for those who live in the plains. Most steel roofing is coated with a zinc or zinc/aluminum material to resist rust. Steel also won't be affected by high heat or harsh weather. The drawback to steel is it's heavy, and not suitable for all applications. It's also not as malleable as aluminum, and may be difficult to install on roofs with lots of angles, differences in pitch, or other uncommon architecture.
Tin
Many people assume that tin roofs are only found on very old structures such as barns. But tin roofs have come a long way since these times. Today's tin roof is lightweight, highly resistant to corrosion, and durable. Installation of tin roofs are fast, and generally much less expensive than traditional roofing. Most tin roofs are made only with a coating of tin, using other metal materials for the bulk. This creates the beautiful tin look that many people want, without the noise and unreliability of straight tin.
